I will take for granted that the transmission in the truck is still a manual with a removable bell housing? If so, worst case scenario, you could build a bell housing from steel that would mate the two pieces together. All that would leave is matching the splines and size of the input shaft to the flywheel, which should not be too hard if there is a good machine shop in the area. I will see if I can find the article, but several years ago a man in GA put a perkins deisel in a mid-late Chev pickup and tested it at Atlanta speedway. It got something like 70 MPG......but I have not heard anyhting else about it since....Plus you may consider a "google" search on the subject. There just may be someone making an adapter or swap kit.
Kelly |
| The Following User Says Thank You to carolinacustoms For This Useful Post: | ||
bob1970 (01-20-2013) | ||
Idk how similar it is but most swaps I've done with Isuzu and Cummins they have an sae boot pattern.so after I find out which one I just buy a $400-700 adapter for the transmission I want to use
| The Following User Says Thank You to monster76 For This Useful Post: | ||
what monster just posted. The industrial bell housing has a lot of interchangeable parts. My neighbour had a GMC pick up with a forklift diesel and a 6 speed.It was fairly cheap on fuel but for accelleration,you timed it with a calendar. Most farm machinery are under 100 horse power,with a lot more closer to 40 horse power.If you plan to just have a fun project,go for it.If you plan to drive it on the road as a daily truck,better do the math to see if its worth bothering with?
| The Following User Says Thank You to vinniekq2 For This Useful Post: | ||
| 1965 AMC Rambler American Engine Swap | imaginaryderek | Engine | 34 | 08-13-2012 03:33 PM |
| 1965 F 100 Ford, swap engine from 6 to V8 with same transmission? | John Steiner | Transmission - Rearend | 6 | 03-26-2012 06:28 PM |
| 1965 c-10 230cid engine, trans swap questions | hogring | Transmission - Rearend | 5 | 10-05-2009 01:03 PM |
| 2001 chevrolet engine and tranny swap | gibsonballs1 | Transmission - Rearend | 1 | 11-24-2008 05:56 PM |
| 1953 Chevy Pick-up | greywulf | Introduce Yourself | 5 | 10-10-2004 11:04 AM |
