We're winning the case!
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 09-18-2007, 02:11 AM
BMM BMM is offline
Swap a 2004r to t-350
Hello. While I realize this is taking a step backwards, I am getting rid of the 2004r in my 88 Chev powered Cutlass, and going with a th-350. Its going to cost me alot more to get the 2004r rebuilt than to get a 350, and I have very little money.
Anywho, the 200r4 is controlled by a TV Cable, wheras the th-350 is not? How do I run the kickdown cable properley on the 350, and set it correctly? Are there any other lines that need to be hooked up that are different than the 2004r?
Also, I planon putting a floor shifter in, but my car is currently a column shifter. Do I just place it in the park position when I remove it, and set up the linkage to the new shifter and it will be fine?
Thanks for all your help. I cant even make it up hills anymore....
Old 09-18-2007, 08:10 AM
Crosley's Avatar
Crosley Crosley is offline
Crosley's barnstar
Wiki editor
Last wiki edit: How to identify a Ford V8
Wiki Edits: 709
the cable for the t-350 hooks up the same... start at full pull at WOT .
you need a vacuum line to the t-350 modulator... direct manifold vacuum
At the Bonneville Salt Flats... 130mph is known as First gear ...............
Old 09-18-2007, 05:23 PM
BMM BMM is offline
Thank you.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Swap a 2004r to t-350"
Distributor Tuning and Theory - Part 1 Rick WI Engine 34 07-26-2008 04:59 PM
Engine swap Chevy 350 ina a Datsun 521 truck evh5150 Hotrodding Basics 17 09-12-2007 10:58 AM
400 to a 350 engine swap any tips?? sparks55918 Hotrodding Basics 8 11-15-2003 04:27 PM
Need Help!!! 326 Swap with 350 Chevy Engine greg67 Engine 13 11-06-2003 11:44 AM
2004r vs trubo 350 gerry Transmission - Rearend 3 05-19-2003 09:20 AM
