Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Swap 250 engine and saginaw 3sp to 350 engine with t-350 or another manual?
Old 02-02-2011, 09:43 PM
mud.man.rj's Avatar
mud.man.rj mud.man.rj is offline
6 to 8
Done a few with t350, the 6 cyl sits back further than an 8cyl, so the 8 will bolt right in but sits back close to the firewall, especially the distrib. If you don't mind this you can usually use the same drive shaft for length. Sometime you have to swap yoke length only. If you want to keep the same 2 core rad just add an electric fan for better cooling.
