swap 3 on the tree for auto trans. - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2004, 05:57 AM
New Member
Question swap 3 on the tree for auto trans.
I have a '63 fairlane wagon with a 3 spd trans. I want to switch it with an auto because I'm putting a 351C or a 302 in it and It will be much easier for my wife to drive. My question is where to put the shifter. Should I cut a hole in the floor and have a console or try and use the shifter from the 3 on the three. Which is easier/better?
Thanks,
Dragon Wagon
Old 03-06-2004, 06:18 AM
poncho62's Avatar
Wiki Edits: 5
Easiest thing would be to swap the steering column for one from an automatic, if you can find one. The 3 on the tree would not work very well.
You will probably end up getting an aftermarket floor shifter, but then theres the problem of bucket seats etc.
Old 03-06-2004, 10:58 AM
dmorris1200's Avatar
doesn't play well with others
If it were my car if it fits I would use something like a B&M Z-Gate shifter like this one and just remove the shifter arm from the column. Different people like different shifters but I have used more than a couple B&M's and like the Z-Gate for the price.
BUILT FORD TOUGH
Old 03-06-2004, 02:38 PM
poncho62's Avatar
Wiki Edits: 5
Betcha, an old 60s Mustang shifter would fit nicely too.
