Swap a 4l60E for 4l80e guestions - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2011, 10:47 PM
Panelman55's Avatar
Loving God living in the South
I have a 2000 Chevy Silverado P-U, I wanted to upgrade the trans from a 4L60E to a 4L80E or 4L85E. Is it a direct swap? What will I need to do the swap other than the trans? Will I need to reprogram the ECM? I was hoping by doing the swap it would give me a stronger more reliable truck. Any feeed back would be of great help
Old 02-06-2011, 03:21 AM
SSedan64's Avatar
The 4L80E/85E is longer than the 60E so the Driveshaft would need to be shortened. May be able to just slide the Trans Crossmember back, mounting holes are probably already there. I'm not sure about the ECM programming, someone on here will know.
Old 02-06-2011, 10:05 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Wire pin locations in connector are slightly different. Yoke spline count is different, length of trans is different, bolt pattern flexplate for converter is different, ECM programing needs changes.
Camaro guys perform this swap often. I would suggest investigating the Camaro forums for proper swap info.
Custom converter built with same diameter bolt pattern to flexplate would be suggested
4l60e to a 4l80e rabennett001 Transmission - Rearend 3 05-12-2010 09:29 AM
4L60E trans vs 4L80E pavetim Transmission - Rearend 6 11-26-2009 11:42 AM
Intresting 4L60E To 4L80E Swap Stanley H Transmission - Rearend 4 01-24-2009 10:24 AM
4l80E and 4l60E Tweek Transmission - Rearend 5 03-21-2007 07:10 AM
4L60E v 4L80E sword1812004 Transmission - Rearend 13 01-21-2007 07:09 PM
