-   -   swap 4l60E trans out of 1995 vandurra 2500 for 4L80E (http://www.hotrodders.com/forum/swap-4l60e-trans-out-1995-vandurra-2500-4l80e-229698.html)
coach777 02-18-2013 07:51 AM
Good day, i could use some advise , i would like to swap my 4l60e tranny out of my 1995 gmc vandurra 2500 for a 4l8oe from a 2003 1 ton pickup , any help on pitfalls and maybe opions on what torque converter would be greatly appreciated, coach
Crosley 02-18-2013 07:58 PM
I edited the thread title so members would have an idea what you are doing.
You will need to change the drive shaft Yoke to 32 spline of the 4L80E and length of drive shaft will be shorter. I would suggest mounting the trans and measure for length
Build or modify a crossmember for the mount
There are wire pigtail adapters available to convert from 4L60E to the 4L80E , you will need the PCM re-programed for shift sequence of the 4L80
Depending on your engine size, there should be a flywheel available to use with the new trans combo
coach777 02-19-2013 08:57 PM
transmission swap
thanks for the info
coach777 02-20-2013 08:15 AM
transmission swap
crosly, your answers have opened up new ? is my 1995 computer programable, are we flashing to maatch the torque or the tranny or both, are we doing this cause i was looking at new tor. convert. with stall 2600-2800 or can you flash orig. tor.conv. to set shift points and where can i get this done , am i shortening the shaft or is the new yoke a shoter than usual special one, thanks coach
