swap 4l60E trans out of 1995 vandurra 2500 for 4L80E - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2013, 07:51 AM
Good day, i could use some advise , i would like to swap my 4l60e tranny out of my 1995 gmc vandurra 2500 for a 4l8oe from a 2003 1 ton pickup , any help on pitfalls and maybe opions on what torque converter would be greatly appreciated, coach
Old 02-18-2013, 07:58 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I edited the thread title so members would have an idea what you are doing.
You will need to change the drive shaft Yoke to 32 spline of the 4L80E and length of drive shaft will be shorter. I would suggest mounting the trans and measure for length
Build or modify a crossmember for the mount
There are wire pigtail adapters available to convert from 4L60E to the 4L80E , you will need the PCM re-programed for shift sequence of the 4L80
Depending on your engine size, there should be a flywheel available to use with the new trans combo
Old 02-19-2013, 08:57 PM
transmission swap
thanks for the info
Old 02-20-2013, 08:15 AM
transmission swap
crosly, your answers have opened up new ? is my 1995 computer programable, are we flashing to maatch the torque or the tranny or both, are we doing this cause i was looking at new tor. convert. with stall 2600-2800 or can you flash orig. tor.conv. to set shift points and where can i get this done , am i shortening the shaft or is the new yoke a shoter than usual special one, thanks coach
Swap a 4l60E for 4l80e guestions Panelman55 Transmission - Rearend 2 02-06-2011 10:05 AM
4L60e 1995 Caprice trans, Buy another one or Rebuild Seanj Transmission - Rearend 3 12-09-2009 06:05 PM
4L60E trans vs 4L80E pavetim Transmission - Rearend 6 11-26-2009 11:42 AM
Intresting 4L60E To 4L80E Swap Stanley H Transmission - Rearend 4 01-24-2009 10:24 AM
1995 gmc 2500 4L80E alabamasho Transmission - Rearend 6 10-19-2007 05:03 PM
