There are 3 different length of the t-350 trans in a 2 wheel drive design.
there are : 6 inch tail housing , a 9 inch tail , and a 12 inch tail. The 9 inch tail housing is near identical to the 700r4 length. Check the adapter kit for the torque arm to see how this bolts up to the car cross member .
At the Bonneville Salt Flats, first gear is known as 130 mph. |
http://www.nastyz28.com/forum/showthread.php?t=53671 |
i got it, ill cut my monty carlo drive shaft to fit the 6in tail shaft.
the bracket i need to mount the tourqe arm cost 99.00$ +tax, from hurst. it mounts the stock rubber to its location on the new mount. ill sell the old aluminum drive shft to buy the kit. every thing cones in the kit to change the trans. thanks guys. |
| 200r to 700r4 swap help | dch921 | Transmission - Rearend | 5 | 11-19-2007 06:19 PM |
| engine and trans swap | 32wizard | Engine | 1 | 03-28-2007 05:16 PM |
| 700r4 to th350 swap | ragincajun19 | Transmission - Rearend | 5 | 03-17-2007 08:42 PM |
| TH350 to 700R4 Swap Question | 70bird | Transmission - Rearend | 1 | 01-14-2007 08:34 AM |
| AOD into mustang | Stangman196700 | Transmission - Rearend | 3 | 12-16-2004 08:51 PM |
