Swap engines on a 1949 Ford F1 truck from 6cy to V8 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-07-2009, 03:31 PM
Hi
I have a 1949 Ford f1 truck with original flat 6CY engine with 4 spd manual trans.
Would like to put a V8 with auto trans.....
Dont wana go crazy ,,,,What is my best choice,,,302 maybe ?? what kind car would be the best donor?
any ideas how much would be a fair price to be charged ?
Located in CT .....
Thank you for any help....
Old 05-07-2009, 03:48 PM
I think you'll have a lot of room to work with; should have a pretty much open book on what you can put in.
302 would be probably the simplest choice, or a 351W. That's assuming you want to stay with Ford engines. Put in the corresponding automatic, or a later model 4 speed to make things smoother.
Old 05-17-2009, 10:02 PM
Last journal entry: `63 fairlane
I used a 302/C-4 combo from a `74 Ford Torino in my old truck(`52 F-1 ). use motor mount & transmission crossmember kits from Speedway in Lincoln,NE.(speedwaymotors.com), I also used the rear axle from a `58 F-100 W/ auto trans. to get better gears.
hope this helps,let me know if I can help more.
Old 05-19-2009, 10:12 AM
machinist & fabricator
i think a FE would look nice in that!
find a beat up ole late 60's or early 70's f-series..
you can also use the rearend... and towing wont be a problem if you decide to...
my 0.02!
Old 04-14-2013, 06:50 PM
1949 4 speed tranny
I know this is a long-shot, but is the old 4 speed available? I need one to replace my 3 speed in my project.
thanks,
PM
Columbus, GA
Old 04-14-2013, 09:11 PM
RWENUTS's Avatar
It's a longer shot than you might hope for. The op hasn't been on here for 4 years.
Best V8 Engine For A 1949 Ford Truck F1 drsergio Engine 15 05-04-2016 12:21 PM
1949 ford f1 brakes continue drsergio Suspension - Brakes - Steering 1 09-15-2008 12:53 PM
35 Ford Coupe front clip on 35 Ford truck 35hotrodtodd General Rodding Tech 8 12-27-2007 03:00 PM
Amazing Discovery about Ford F1 Gauges. lakota Hotrodding Basics 6 12-19-2007 01:44 AM
1949 Ford F1 mw1151 Introduce Yourself 1 06-26-2007 12:06 PM
