Swap out rear gears in 84 olds 98? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2007, 03:10 PM
i have a 84 olds 98 equipped with what i think is a 8.5 with tiny little 2.40s in it
i don't have enough money to buy new lower gears and a carrier, is it possible to swap the carrier and gears out of some other vehicle and put them in my axle like out of a pickup for example?
anything would be greatly appreciated.
Old 06-13-2007, 09:34 PM
You are correct - this is the standard 8.5" ten bolt GM corporate C-clip axle. Most 80s vintage carriers and gear sets bolt into your housing. 80s F-body cars are good sources. So are full size Chevy cop cars and taxis.
Old 06-14-2007, 09:40 AM
thanks alot!!!!!
Old 06-15-2007, 01:06 PM
what about out of old chevy pickups?
40 Olds rear end nomaddaddy Transmission - Rearend 1 07-14-2005 07:21 AM
74 to 65 rear end gear swap? 65_Chevy Transmission - Rearend 4 06-26-2005 02:29 AM
Strange vs Motive Rear Gears, also which ratio: DTL504 Engine 4 04-28-2005 02:36 PM
12 bolt olds swap CHEVELLE12345 Transmission - Rearend 2 03-15-2005 03:21 PM
84 camaro rear brake conversion Chevelle71 Suspension - Brakes - Steering 1 02-19-2004 05:06 AM
