Swap small block chev into 53 ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-21-2002, 07:03 PM
Post Swap small block chev into 53 ford
Hello, I am finally pulling the flathead in my 53 ford wagon.I am all set with a mildly built 350 chevy motor. I have the new mill slid in and when it is slid back far anough to clear the radiator, the oil pan hits the steering tie rod.......Any sugestions ??
[ January 21, 2002: Message edited by: Kasper ]</p>
Old 01-21-2002, 07:16 PM
HotRodF100's Avatar
Smile
I have a 350 in my '53 F100 but mine is sub framed. I did however notice that they had to offset the motor mounts to get it in. They made plates and welded them in the cradle and mounted the motor mounts forward. Even at that, the motor sits real close to the firewall. Every one that I have seen with a SBC seems to fit the same was as mine. HotRod
Old 01-21-2002, 07:27 PM
Post
Guess I forgot to mention that it is a 1953 ford two door wagon.
Old 01-21-2002, 08:07 PM
Post
Not sure if its still done this way but a dropped tie rod gave the needed clearance.
Old 01-22-2002, 03:43 AM
Post
try a chevy monza or older chevy 2 oil pan and sump is a lot cheaper than buying an after market pan and sump
Old 01-22-2002, 09:32 AM
Thumbs up
For the 53 Ford flathead to chev. Contact Speedway motors www.speedwaymotors.com.
Old 01-22-2002, 01:02 PM
53vicky's Avatar
Post
I am in the process of installing a SB Chevy in my 53 and was instructed to call Butch's Rod Shop in Ohio. (937-746-7459) This is their tech line.
Old 01-22-2002, 04:56 PM
New Member
Question
WHAT WAS WRONG WITH THE FLAT HEAD??? I'M LOOKING FOR ONE.--------CAJUNONE99
Old 01-23-2002, 03:34 AM
Post
I put a small block in my 53 ford 2 door mainline...... It said inthe directions for the mounts that u either have to bend the control arms down or get new ones that are lower. Also when i put mine in, the distributor hit the firewall and the directions said that clearnace shoudl be fine... whatever. I can;t think of the name of the place that sells the linkage... i think they are in NC and they have a web site....... O ya http://www.fatmanfab.com u gotta look ahrd but they have the lowered control arms.
Old 01-23-2002, 05:05 PM
53vicky's Avatar
Post
The FatMan Fabrications dropped steering arms are made to maintain proper geometry when using their dropped spindle system. The problem is the center drag link needs to be droped about an inch to clear the oil pan.
Old 01-24-2002, 04:25 PM
stevesauto's Avatar
Post
you can change the front end to rack and pinon
or try to get a low profile oil pan.
thank you
steves auto
Old 02-07-2002, 09:19 PM
Talking
Are you using a conventional fan & shroud? if not you may be able to move it forward enough and use an electric slim profile style fan. Another option is to use a different oil pan & sump which relocates the drop out of the way. The Chev sb was available in so many different vehicles including vans to Monzas so one should fit without the expense of suspension alteration.
Good luck! ~~Metalman~~
