Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - swap from split rims to solid rims
Old 04-05-2005, 03:31 AM
aka Duke of URL
The easiest way to go about this would be to identify the exact front and rear axles you have on the truck and then cross reference that axle(s) to the ones having disc wheels in that period (For example you may find the correct hubs on a F 600 dump truck). It would be mean most likely finding another vehicle with disc wheel hubs instead of spoke wheel hubs and just performing the changeover.
Worse case scenario would be upgrading axle assemblies from a later vehicle.
