-   -   swap a TH350 for a four speed? (http://www.hotrodders.com/forum/swap-th350-four-speed-10040.html)
bildo95 01-31-2003 06:55 PM
I have an 81 camaro with a TH350 in it, I would like to drop in a four speed. Did the Z28's come with the four speed option? What tranny was this? What manual would work best? How much is a used manual tranny run now days. Thanks for your help, and give me any and all suggestions or options. Thank you, Bill
kiaserknife 01-31-2003 07:12 PM
I dont know the answer to your question about it being a option.....but I do know unless your going to use a hyd clutch set up you need to first check and see if your block is drilled to use a clutch set-up....alot of blocks are not drill and tapped for the bell crank...this can be fixed by drilling the boss in front of the oil filter housing.....but its next to impossible to do in the car....check that first....
ronb 02-01-2003 08:08 AM
there was an 80-81 Z28 that cam from the factory with a 4 spd, but i cannot remember what it was?
81z28 02-02-2003 06:43 PM
Cool, I'm looking to do the same thing with mine. The 80&81's came with a saganaw slush box, I'm looking to put in a muncy M21, had one in a vega, it was the best tranny i've ever shifted. Good luck, and keep me up on the progress. :cool:
