I dont know the answer to your question about it being a option.....but I do know unless your going to use a hyd clutch set up you need to first check and see if your block is drilled to use a clutch set-up....alot of blocks are not drill and tapped for the bell crank...this can be fixed by drilling the boss in front of the oil filter housing.....but its next to impossible to do in the car....check that first....
