Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Swaping TBI for Carb - Need Advice
Old 05-20-2010, 11:58 AM
FastOrange's Avatar
FastOrange FastOrange is offline
You can use the stock TBI fuel pump and use a Holley Bypass Regulator to regulate down to carb pressure.
I just did this swap in my C1500. Went from a 4.3L TBI to a Carb 350.
Im using a HEI Distributor, Demon carb, and i bypassed the oil psi unit wiring, since mine broke and if the fuel pump doesn't get a signal, it wont run.
