Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - swapping 1951 truck body to late mod. chas
Old 11-16-2002, 10:28 AM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Wiki Edits: 21
Post
Keep the stock frame and install the front x-member form a 70s Chevy 1/2ton. Gets you modern coil springs, power steering, sway bar, the works. Very easy to install - weld two 1/2" plate spacers on the sides of the frame, drill and tap 4 holes/side then bolt it in. I have a scanned article on the installation if you send me your email address, I'll send it to you.
