Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - swapping 2.56 gears to 3.50 gears
Old 05-16-2009, 09:02 PM
fast68's Avatar
fast68 fast68 is offline
likes chevy trucks & boobies
yes 2.56 and around 3.42 and up are different series from each other
the reason is that the ring gears are different thickness for each series and thus the ring gear mounting flange on the unit is in a differnet location to make up for this, because series 4 pinion gear heads are smaller diameter, around 9 teeth,
vs series 3 pinion heads in which are larger diameter and have more teeth with the taller ratios such as 2.56 and 2.73
3.50 is a ford ratio
gm will be 3.31 3.40 3.42 3.73
2.56 is series 3
around 3.42 and up are 4 series
