swapping 305tbi to 350 tbi - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-27-2012, 10:49 AM
what do I nedd and have to change
Old 02-27-2012, 01:09 PM
Probably the chip in the computer or get the 350 computer. The 350 has 45 more cubes to fuel, the 305 and 350 share a lot of injection parts but usually they use different injectors the 305 using 45 lb/hr and the 350 either 55 lb/hr std duty or 65 lb/hr heavy duty. If you use the 350 TBI with the 305 computer you might get away with it. But the torque development of these engines will put the fuel map slightly off which is why I suggest the 350 computer with the 350 including its TBI with the bigger flowing injectors. It's a matter of getting the throttle position, which dictates manifold vacuum, into synch with manifold vacuum to RPM.
Bogie
Swapping a 305 for a 350? bdubyah Engine 20 05-16-2011 06:52 PM
305tbi to 350tbi (or carb) vortec swap enduro54 Engine 3 05-12-2009 08:44 AM
1989 Camaro 305TBI problems illflyhi Engine 1 01-30-2008 06:57 PM
Swapping a 3.8 for a 4.3 ??????????? Stick'n It Engine 6 06-20-2004 11:09 PM
swapping ls1 cam to a ls6 67bird Engine 7 02-25-2004 04:45 PM
