Swapping 700r4 from 4.3l to v8 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2011, 12:21 AM
GMMAN's Avatar
I am wondering a few things about a 700r4 swap that I haven't been able to come up with, and it could be just be that Im pretty tired right now but my question is this.
I am going to swap a 700r4 that was behind a 4.3l 1992 safari van into my 1981 malibu station wagon, the question is, do I have to buy a converter for a 350 700r4, or will the 4.3l torque converter work?
I am guessing the 4.3l converter would not work, but WHY is the question, will it give me a higher, or lower stall, or just not work at all.
Thanks.
Old 03-20-2011, 08:52 AM
3rdmember
done it before a couple of times, it'll work fine as is.
if there's a stall speed change, i couldn't tell...
what rear gears are in the wagon?
if it originally had a 3 speed trans (non-overdrive), they may not be deep enough for the OD and it'll be a pig to drive...
just a thought..
Old 03-20-2011, 08:53 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Use the converter. The 4.3 converter is slightly higher stall than an OEM converter for the V8... you will not really see - feel much difference with a stock V8 engine
Old 03-20-2011, 11:12 AM
GMMAN's Avatar
This is great news as I already have to pick up the TCI lock up kit, shorten the driveshaft and do a few other mods, glad to hear one thing will work
Lookiong forward to overdrive
Swapping 700R4 Internals 6426yy Transmission - Rearend 4 04-28-2009 11:27 PM
Swapping 700r4 for T-400 BlackCamaro Transmission - Rearend 4 11-05-2008 12:34 PM
Swapping powerglide for 700R4 hunt101 Transmission - Rearend 3 11-28-2006 09:21 AM
Swapping to 700r4 worth it? Jmark Transmission - Rearend 11 07-03-2006 05:15 PM
Swapping a 350 for a 700r4 in 69 bird fletch69 Transmission - Rearend 1 11-25-2002 04:47 PM
