Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Swapping to 700r4 worth it?
Old 07-03-2006, 05:15 PM
fast68's Avatar
fast68 fast68 is offline
likes chevy trucks & boobies
it should get a little better mileage than that, you can buy a new Q jet carb for 150 at o reilly auto parts i got one for my '77 4x4 with the original 400 sb in it and it really good on gas alot better than your c-10 is getting by FAR
its all in the carb
run a Q jet
they are fuel efficient, more than other carbs are
or get a car or later truck,
also your axle would be 3.42 not 3.41
there was also 3.40 in these trucks these years it was RPO code HE4
check RPO sticker in glovebox
you may be confused with the 2.41 ratio of the late '70s GM 7.5" 10 bolt axle cars
good luck
