Swapping from A4 to T56 -- can anyone help with wiring? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-12-2011, 02:50 PM
Last journal entry: More information
Hey guys,
I've swapped my 4l60e out of my Jaguar XJ6 conversion project -- however I want to use the same harness that I had before (lots of wires integrated... it'd be a hassle to re-do it all over again, not to mention finding a new harness....)
I was wondering if anyone can help me with the wiring diagram for a T56 vs 4l60e -- i figured out the reverse lights and speedometer. However, the reverse lockout solenoid is throwing me for a loop. I read that one of the 20 wires in the 4l60e green transmission plug has a wire for this, but I'm not sure how i'd wire this to make it function with the T56 --
On the 4l60e, there was TC lockup, which i wired to a 4 way switch on the brake pedal -- effectively i had 2 functions from one switch, brake lights and TC lock up. Someone said you can wire the reverse lockup solenoid to this, but it doesn't lock the solenoid like it is intended to be -- i believe the solenoid activates once you are driving 3mph~.
has anyone had any experience doing this? Any tips?
Old 01-12-2011, 05:17 PM
big gear head's Avatar
High Performance Rear Ends
You might try asking these guys. I'd say that one of them has done this. http://www.ls1gto.com/forums/forumdisplay.php?f=7
Swapping to 5.7 TPI using 5.0 TPI.. few q's boneyard Buick Engine 1 06-23-2008 11:21 AM
Swapping 307 for a 350 dch921 Engine 4 08-12-2007 12:49 PM
Swapping Denis Engine 2 10-23-2004 10:32 AM
swapping ls1 cam to a ls6 67bird Engine 7 02-25-2004 05:45 PM
Swapping a 10 for a 12 HotRodS10 Transmission - Rearend 3 06-26-2002 08:03 PM
