-   -   swapping drums to discs (http://www.hotrodders.com/forum/swapping-drums-discs-86647.html)
TORI1 04-11-2006 03:41 PM
I've got a 71 camaro 10 bolt Drum brake rear end with 28 spline axles and 5-on 4.75" bolt circle.
i want to switch from drum to disc brakes...
do I need to use a disc brake system from a 70' to 81 camaro, or will other GM disc brakes form a 10 bolt rear end (not necessarily off of a camaro) bolt onto my existing rear end??
if so... what will work???
thanks
nevermind 04-11-2006 07:30 PM
I would suggest to you, find a 78-80's W36 optioned Trans Am...and grab the whole rear end with the discs, proportioning valve, and master cylinder...I seem to remember the rear wheels had a one more offset...don't remember why though...for clearance or just for looks?...maybe someone else will speak up...Cheers! :thumbup:
TORI1 04-12-2006 09:40 AM
rear end..
I dont want to swap for a different rear end...
I'm looking for Bolt on Disc Brakes for my existing 71 camaro rear end.
onovakind67 04-12-2006 10:10 AM
Some info here:
http://www.buickperformance.com/reardisc.htm
http://www.buffnet.net/~airrj/Rear%20Brakes.html
http://www.geocities.com/diels12000/...rakes.html#s10
You might also ask the same question here:
http://www.nastyz28.com/forum/index.php
bullheimer 04-12-2006 10:12 AM
www.scarebird.com
