I would suggest you get at least 2 things, a digital camera and a copy of the chassis service manual(Helms, not Chiltons). The manual will show you how everything comes apart, and the camera will let you take pictures of sub assemblies so you can remember how they re-install correctly.
You'll be much better off if you un-bolt everything you possibly can, anything you have to cut or torch ends up being a possible issue later on. |
Alrite I have no idea how to swap the wiring harness... Any ideas or advice?
Ya but the thing is that in order to get to the nuts on the bolts of the mounts I gota drop the front end, there's no space to get a wrench or anything on the nuts with the front end right underneath the only opening the nuts
So I got the whole motor and powertrain in my s10 and everythings is hooked up that know of but every time I turn the key to the run position it pops the ecm1 fuse and I can't figure out why, any ideas?
What shout I look for? What would be the most probable cause of popping the ECM1 fuse after doing this motor swap?
So I figured out that I have to swap the hole inside harness underneath the dash, I can't follow the fuel pump wires and sum other wires. Can anyone get me some in depth wiring diagrams or info on a 1988 s10 2.8l and a 1989 s10/blazer 4.3l
| 1998 blazer tranny blew can I swap engines | disice1011 | Transmission - Rearend | 1 | 12-04-2008 01:31 AM |
| plz help s15 blew up. 98 blazer tranny blew cani swap engines | disice1011 | Engine | 2 | 12-02-2008 09:33 PM |
| swapping engines in a ford 350 | woodmanscott@hotmail | Engine | 4 | 11-23-2007 08:18 AM |
| swapping engines | Ben D | Engine | 2 | 03-03-2006 07:06 AM |
| Swapping engines. | Skunk | Engine | 2 | 11-07-2004 01:20 PM |
