Swapping heads on a 383 SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2005, 10:50 AM
72Nova383's Avatar
Im sure this has been discussed many times but how hard is it to swap the head on my 383??. I mean i have never done it and im considering buying some new heads. My motor is a 383 with the stock cast iron heads on there. I have no idea what cam was put in there, thats my problem. It does have a nice lope to it, but who knows. I have a holly contender manifold on there right now with a holly 670 street avenger carb. I have a Edlebrock airgap i just bought and am going to install. I was just giving it some thought, and while i was in there maybe changing the heads to get some more horses. I want to spend between $1000.00-$1400.00. I was lookiong at some 23 degree trickflow heads in Summit, but maybe you guys have some other ideas for my application. thanks
Old 03-06-2005, 12:02 PM
GoneNova/406's Avatar
from everything that i have seen on the car shows on t.v. and that i have read over the last 5 yrs. or so with that kind of money i would go with AFR.check them out at their site.also go to westtech performance group and check out the head tests.you can link to them from AFR.good luck.
Old 03-06-2005, 01:28 PM
strikingthematch's Avatar
Pure American Muscle
Last journal entry: Still Going
All depends on what you want. AFR heads will cost you around 1300 and have about 6 weeks waiting period.
Then you have to think about the cost of all the other parts. If your getting new rockers are they goning to be roller rockers at around 200 or stay with new stamped steel. Then the cost of push rods. New heads gaskets (good fel-pros). AFR suggest you use new head bolts or studs. Then all the gaskets (intake, exhaust)
All around you can look at close to 1600-1700 if you go that way. All other things aside you will have a great head on the engine. I got them and couldn't be happier. If you can't do your own porting or don't want to pay to have someone do it on other heads then AFR are your friend. Don't forget there are a number of great heads out there that are cheaper then AFR. What are your future plans for this engine?
Chris
Old 03-06-2005, 01:48 PM
72Nova383's Avatar
Thanks for the replys. I will look into the AFR's. As far as plans thats about it the motor only has about 20'000 miles on it. I am debating on buying some heads for it. I have a MSD 6A on it right now and a MSD distributor im going to put in it. I have the Air Gap manifold for it put am waiting and trying to decide if im going to get some heads before i put the Airgap on it. Id defintley love to get some more hores out of it. I just put 3:73 posi in it.
Old 03-06-2005, 01:58 PM
Besides the heads did oyu look into a new cam? With those gears in the back you may be able to get a much better run out of the car with a cam that puts the powerband where it works together with the gears. You might be able to go with something like DART heads that will be chaper and leave you some extra for a cam or a TQ conv. that way everything in the set up works hand in hand and you will have a smooth ride with all the power sittin inside.
Chris
Old 03-06-2005, 05:55 PM
lluciano77's Avatar
I prefer cast iron on the street. I own both. My aluminum heads always make me feel nervous. I can just picture them warping. Beside cast iron makes more power.
Like STM said, you will have more money for other parts.
'76 400 SBC cracked heads 87Camaro Engine 5 04-19-2004 12:01 PM
bowtie heads for sbc Eddie Baker Engine 3 11-09-2003 12:02 AM
heads? last 3 #s on sbc heads [441] inkfixer73 Engine 5 08-18-2003 07:38 PM
SBC 400 heads wcpalmex Engine 2 06-15-2003 09:56 PM
SBC Heads fred56 Engine 4 10-27-2002 08:54 AM
