Swapping Heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2006, 01:46 PM
Swapping Heads
I was told that putting 305 heads on a 350 block would increase HP, but risks burning a piston. Is this true, and if so, how much HP and how great is the risk?
Old 03-28-2006, 09:13 PM
MI2600's Avatar
Member# 3287
The 305 heads will increase compression because they have smaller chambers. I don't know why they would "burn a piston".
HP increase? Depends on the rest of the engine.
Old 03-28-2006, 11:23 PM
Compression will be gained but at the cost of smaller valves in the 305 heads.
Old 03-30-2006, 12:42 PM
Rev It Loud, Drive It Proud!
Dont waste you time with the 305 heads. They arent going to flow enough for your 350 ( small valves, small ports ). Opt for maybe some old camelbacks or a vortec head. Better flowing ports and bigger valves, plus with the 64cc chambers it should give you decent compression.
Old 04-02-2006, 10:46 PM
techinspector1's Avatar
Wiki Edits: 326
The "burning a piston" part of it could come from the higher compression and resultant detonation on pump gas.
swapping heads chevelle_502 Engine 3 07-13-2004 01:37 PM
Swapping Vortec heads onto 5.7L TBI yukon... TheZaZ Engine 2 05-30-2004 05:42 PM
AFR Heads DTL504 Engine 9 12-09-2003 02:55 PM
Firebird Heads and Rockers 350bird Engine 4 11-12-2003 09:33 AM
bowtie heads for sbc Eddie Baker Engine 3 11-08-2003 11:02 PM
