Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Swapping out 6cyl for 390FE in 1970 Stang
Old 12-13-2008, 08:21 PM
gregb gregb is offline
The crossmember for the C6 is unique, if the one you have under the car now has 4 ears for mounting it wont work because the C6 pan will hit it. I don't remember who, it might be Total Control, makes motor mounts for that setup, might be about the same cost as procuring the frame perches (and yes, you can use the frame brackets with an extra hole drilled, or find some 1967 brackets and you wont have to drill anything), the engine inuslators and the mounts that bolt to the block. Those pieces aren't hard to find but they are usually not cheap. If you go with headers FPA are going to be the only ones that fit the ports properly.
