Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - swapping rear ends, brake question.....
Old 03-30-2004, 10:26 PM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
The only way you might avoid air in the lines is to first remove the rear cover, then pull the axles, then unbolt the backing plates, then drop out the bare housing then re-assemble in reverse order.
