swapping steering column - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-08-2004, 03:58 PM
New Member
Question swapping steering column
I'm swapping out my 3 on the tree for a ford aod trans. on my 63 fairlane. I went ahead and bought a new steering column out of a 64 galaxie(hoping it fits). My question is will it work right with an aod trans. considering the galaxie had a c-4 tranny? or can it be modified if need be?
Thanks
Old 03-08-2004, 04:19 PM
Thom Laybourne's Avatar
I am not overly familiar with your trans, but connecting it to the steering column should be the same. Both transmissions have the shift lever on the driver side? Linkage might be different where it connects to the transmission, OVAL vs RECTANGLE. But the column should work. What is the difference in the columns? TILT / OD button?
hr41pearl
Old 03-08-2004, 06:49 PM
New Member
The only difference I know of is one's standard and one's auto. The main thing I'm concerned with is the gear pattern, since the c-4's were 3 spd autos and the column doesn't have an over drive selection.
Old 03-09-2004, 09:18 AM
STK / AUTO
So, the only difference in the two columns is the fact that stick has two rotating levers and the auto has one rotating lever. So the new auto column should work with not problem. You might want to get a lever for the transmission from someone like Lokar. They make them in different lengths, which give better leverage to the column.
hr41pearl
Old 03-31-2004, 03:50 PM
C-4 to OD?
I'm pretty sure the OD still has the same number of detents. There isn't a seperate one for 3rd (or high) Just L, 2nd, and OD. At least that's what I recall. I do know that some guys in the Galaxie club have done this with no problem.
You could ask here to: Ford tranny talk:
http://www.network54.com/Forum/260730
Later, Phil
Old 12-19-2006, 05:50 AM
Steering column
My son has a 68 Mustang which we converted to AOD. Although it is a floor shift the principal is the same. The tranny fits in as does the driveshaft, but the cross member has to be altered or constructed. The linkage bolts up, remember to set the selector line up. A kickdown cable MUST be hooked up and a neutral safety switch must be wired in to the existing harness. It took us a weekend to do this, lying on our backs under the car but it was worth it. The fuel mileage went from 18 mpg to 23 mpg. Hope this helps
Oldcat68
Old 12-19-2006, 06:05 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
Check the date of the post you responded to.
Old 12-19-2006, 06:10 AM
Aod
Sorry... 1 thing I forgot to mention... you will need the AOD flex plate or have your plate rebalanced. Any good transmition shop or hp engine builder can do this for around $50.. Good luck..
Old cat68
Old 12-19-2006, 06:12 AM
0ops
Sorry..oldcat68
