Swapping TH350 for Saginaw 3spd. What do I have to change? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-03-2010, 08:18 PM
Cknarf's Avatar
Pontiac Pilot
Alright, the tranny I found in the attic a few days ago is a Saginaw 3 speed. I want to install it in place of my stock TH350. I heard that my driveshaft length may be the same, but I'm not sure about that or anything else for that matter. Where would be a good place to find the right parts for the swap? It will be bolted to a Pontiac 455.
Old 07-03-2010, 10:19 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Any idea what car the 455 pontiac engine will be in?
You need clutch pedal and linkage, clutch, flywheel , bell housing to name a few parts.
Do you have some parts or none?
Drive shaft may be the simple item to deal with
Old 07-04-2010, 03:44 AM
Cknarf's Avatar
Pontiac Pilot
It's going in a 1975 firebird formula. The Transmission is the only thing I have right now.
th350 trans fluid change to royal purple.... fireforsin Transmission - Rearend 5 05-09-2009 05:01 PM
th350 cable change Cape Cod Bob Transmission - Rearend 1 04-26-2009 07:32 PM
How do I change fluid in a TH350 Turbo? BIGK Transmission - Rearend 14 09-27-2007 08:31 PM
TH350 to M21 or TH350 to 700R4 thecamaroguy Transmission - Rearend 6 02-10-2005 01:18 PM
Swapping a Muncie m465 to a TH350 TL-Iguana Transmission - Rearend 2 12-26-2003 10:32 AM
