Sway bar ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2007, 09:52 AM
Sway bar ?
I have a '48 Buick that has some kind of GM front clip (Camaro?) welded on to the Buick frame, the steering gear is ahead of the main crossmember. My question is, what sway bar can I use on this set-up? I can go to the junkyard and find some car to rob the sway bar but don't know which cars might fit.
The car sways in turns and in windy conditions on the hi-way. Thanks, Karl.
Name:	Karl&Buford Oct2006EM.jpg
Old 02-25-2007, 10:07 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
If you think it is GM then just go there and look for front chassis clips similar to yours and rob one of those sway bars..sway bars are simple to install..just need the brackets to bolt to the frame and some links to the lower control arm..there are actually quite a few that could be made to work..
Sam
Old 03-04-2007, 06:25 AM
sway bar
Well I went to the junk yard and found a metric Buick front sway bar, it is 1" diameter and it fit right on the old Buick. I added some new urethane bushings and the car handles much better. Am thinking about adding a rear sway bar now as well.
Sway Bar bushing blues bowtyebob Suspension - Brakes - Steering 6 11-27-2006 06:58 AM
Camaro front sway bar measurements BK455 Suspension - Brakes - Steering 3 06-25-2006 12:40 PM
65 Belair Sway bar question sabino56 Suspension - Brakes - Steering 11 12-26-2005 09:22 PM
1973 Mustang front sway bar question? Steve-0321 Suspension - Brakes - Steering 1 12-11-2005 12:12 PM
Sway bar logic jpd37 Suspension - Brakes - Steering 14 07-24-2003 01:00 AM
