sway bar? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2004, 03:10 AM
sway bar?
I'm not sure if this is a problem or not but where the sway bar connects it looks like there is a gap, like its eneven, its not bolted flat. Is this bad? do i need a new sway bar? i included a pic to help explain.
Old 06-12-2004, 07:58 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Not to worry, those connections are purposely designed sloppy 'cause the parts are constantly cattywampus with each other as the suspension bounces, turns and twists. yours looks perfectly fine. And yes, those bars are one of the best innovations in suspension design ever devised. Leave it in!!
Old 06-12-2004, 09:28 PM
New Member
Cattywampus,man thats one I havn't heard in a long time.
Old 06-12-2004, 10:35 PM
Wiki Edits: 21
Oh, that isn't even getting warmed up. How about 'bogus', 'ginchey', 'rad', 'movin', 'hopped up', 'tapped out' . . .?
Old 06-12-2004, 11:52 PM
You can change the length of the spacer to get the end of the bar perpendicular to the link.
Old 06-13-2004, 07:50 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
It looks normal to me too, I have seen some nastily tweaked sway bar links on four wheel drives here at the shop, but most end up opting for the quick disconnect kits when they find out what their vehicle will do off road.
Old 06-14-2004, 06:49 AM
BillyShope's Avatar
Philippines Cowboy
Last journal entry: THE TRACTION DYNO
How about "slonchwise"? Now, that's paying you back in your own seedcorn! (I grew up in Iowa.)
Old 06-14-2004, 07:21 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
Looks normal to me.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
Old 06-16-2004, 12:59 AM
Put it this way, it's real common for them to end up that way, but they're not supposed to be that way.
Old 06-16-2004, 12:52 PM
Thanks guys, it just looked a little off to me, but if its ok i wont worry about it.
Old 06-16-2004, 01:19 PM
malc's Avatar
Living At The Speed Of Life
It does´nt look right to me, the center line of the end link
is vertical, the center line of the sway bar hole is off to one-o-clock, or laying back.
Here is a pic of mine, in the next few days the links will be replaced along with new polyeurathane bushings.
Old 06-16-2004, 03:12 PM
I'll try to get a better pic this week sometime to better show mine, but it looks worse than urs does.
Old 06-16-2004, 05:32 PM
troy-curt's Avatar
Echo, if yours was tightened more it would look like malcs.
That is the way they are made.
Troy
Old 06-16-2004, 06:42 PM
Wiki Edits: 21
The link's only purpose is to tie the ends of the bar to the A-arms in a very gross manner. No precision intended or necessary. Their appearance, within reason, has no bearing on their function and yours will function perfectly as shown. You could pretty them up a little by installing new rubber donuts and tightening the nuts but they won't operate any differently or better than they do now.
Old 06-16-2004, 07:13 PM
adtkart@aol.com
It appears to me that the weight was off of the suspension when the photo was taken. That would explain the difference in appearance. The whole idea of the design, is so that when pressure is applied to one end of the bar, pressure from the bar is transferred to the control arm at the other end. Neither the bar or the control arms really care what the connection looks like.
When I worked on a race car, we used heim joints with adjusters for the connectors, so we could adjust pre-load on the bar.
