Sway Bar endlink/drive axle question - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2007, 09:02 AM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
I finally got cracking on changing out the drive axle on my wife's '96 Buick Skylark. I just put new front brake pads on this car 4 weeks ago, and didn't notice anything wrong before, except that one of the small metal CV boot clips on the left side had rusted off. When I pulled the wheel off today, I was greeted by a severely torn boot and a broken sway bar endlink. I went around the other side, and found the right side endlink broken too. Now I'm curious as to what I did or how both sides would break like that.
I'm thinking that they might have been broken while our road was under construction (total tear out of old road) and we only had rough access to our driveway. Or, could the left side endlink have broke, ripped the clip and boot off, and then caught the axle shaft just right and side-loaded the right side enough to break? Any hunches? I know I've never seen anything like this...
In a while, Chet.
Sway bar dimensions? staleg Suspension - Brakes - Steering 6 02-26-2007 11:26 AM
wiping out sway bar bushings! WHAZZZUP? bullheimer Suspension - Brakes - Steering 7 05-05-2005 03:02 PM
Sway Bar low77ride Suspension - Brakes - Steering 7 12-19-2003 07:36 PM
front sway bar mount location fire power Suspension - Brakes - Steering 2 05-17-2003 07:10 AM
rear sway bar DeathByGreaser Transmission - Rearend 2 02-07-2003 02:25 PM
