Sway Bar Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2007, 06:49 PM
Retiredrich's Avatar
Sway Bar Question
I have had a Speedway Motors front disc brake kit on my 56 Chevy for about 8 years. The calipers are mounted to the front of the rotors as per the instructions. I want to put a Hellwig Product 1 1/8" sway bar on but I don't know it the calipers will interfere with the link/sway bar. Hellwig could not answer the question. I asked Speedway if I could move the brackets and the calipers to opposite sides making them rear mount thus eliminating any possibility of a clearance problem. Speedway said the kit is meant and designed for front mounting only. I'm still not sure why this wouldn't work but thought I would put it on the forum for discussion. Has anyone used specifically a Hellwig 1 1/8" sway bar with the Speedway disc brake kit and if so does everything clear?
Old 02-26-2007, 08:00 PM
shortyforty's Avatar
Last journal entry: V8 suspension added
I had some SPEEDWAY MOTORS front mounted caliper brackets on the wife's 56 Chevy. The caliper bolts stripped out the bracket's threaded holes cause the brackets were too thin. I spent the extra money for some rear mount brackets from Danchuk, and these were much better. But I will have to tell you that I have also gotten some shabby parts from Danchuk too.
Old 02-27-2007, 06:49 AM
Sway Bar Question
I am considering replacing the Speedway kit with a complete rear caliper mounting kit from another company to eliminate the sway bar clearance problem. I've had my share of issues with the Speedway kit that is now on the car, ie. soft Chinese bearings I replaced, lug nut studs that twisted in the rotor when tightening (ended up replacing the rotors with USA made ones a few years back). Try getting the lug nuts off to get the wheel off when the stud is turning. It's not fun! I would not recommend the Speedway kit to anyone.
What company has a good disc brake kit with quality bearings, rotors etc. for 56 Chevys?
Old 03-01-2007, 08:02 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Nice car!
(wish the rear view would enlarge)
New Anti Sway Bar for 1939 Pontiac rwruther Suspension - Brakes - Steering 2 06-26-2006 12:01 PM
Camaro front sway bar measurements BK455 Suspension - Brakes - Steering 3 06-25-2006 12:40 PM
Want to Add Sway Bar to Rear Axle jpd37 Suspension - Brakes - Steering 5 11-23-2005 04:24 PM
sway bar installation wheel-7 Suspension - Brakes - Steering 8 09-29-2003 06:11 PM
Sway bar logic jpd37 Suspension - Brakes - Steering 14 07-24-2003 01:00 AM
