SWEET DEAL - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-01-2003, 03:29 AM
banned
Post SWEET DEAL
yeah so I downloaded desktop dyno (yeah I know I can't afford it now though will get it later0 anwyas it says I can get 450 HP out of a 400 with stock 882 low perf heads ported.. That is sweet deal.. is this figure wrong... ps I put a hot cam in that was the biggest difference but not the most lift and highest pf since this is a street car
Old 01-01-2003, 03:33 AM
banned
Post
ps is this is with duel plane manifold, long headers with mufflers and .350/.400 lift cam... and hydrolic flat tappit
Old 01-01-2003, 03:34 AM
banned
Post
oh and 750 cfm carb.. it don't make much diff after that
Old 01-01-2003, 03:45 AM
deuce_454's Avatar
Post
well a 400 is a big engine and with a 300 degree cam and a carefull porting allong with other matched components you should be able to get into the 450 Hp range, even with GM heads. I am going to send you a mail with pics of what the port job involves. and when you are done porting and unshrouding the valves to match the larger bore of the 400, then get the biggest valves you can fit in there, and you should be there
Old 01-01-2003, 04:07 AM
deuce_454's Avatar
Post
I know ive said this before but why do you insist on useing those antiquated heads, i mean when a set of stage 2 bowtie heads are only 600 dollars?
http://greenwoodchevy.com/Merchant2/...gory_Code=GMPP
Old 01-01-2003, 09:04 AM
Post
were can i find that desktop dyno
Old 01-01-2003, 12:36 PM
banned
Post
well it goes like this... I am 17 and broke and there isn't much to swapping heads later on so I am gunna put as much money as I can into the bottom end for now and if I ever decide to get new heads or the old ones just don't work out.. I don't have to redo the bottom end... I mean sure I will lose money cuz of what I put into these antique heads but if it is a real problem I can sell them
Old 01-01-2003, 01:45 PM
Post
Is the 400 a chevy, pontiac, or what? <a href="http://www.pontiacwarriors.com" target="_blank">www.pontiacwarriors.com</a> has dyno comparisons using stock heads with slight or heavy porting. They show a 400, bored 30 over, using a comp cams xtreme energy kit, 6x heads, intake, 750 carb, making 450hp and 470#ft. doesn't have alot until 3,000, but with some gearing, you can make up for the bottom end. Check it out, it for nothing else, ideas.
Old 01-01-2003, 05:09 PM
banned
Post
yeah it is a chev... it is so easy to get power out of chev engines (according to desktop dyno) I tried doing a ricer... well ummmmm yeah I had a turbo on it and Nitros and it still didn't compare..
Old 01-01-2003, 05:14 PM
Post
I guess if I were you, I'd drive the car the way it is and buy the right go fast stuff a little at a time. When ya got all the stuff, tackle the build-up. It's important that all the parts are designed to work together, but I realize I'm not telling you what you don't already know. Check e-bay, the local paper, local clubs, etc. and you just might find some great buys. I wish all the really cool stuff wasn't some damn much money!!!
Old 01-02-2003, 12:50 AM
banned
Post
well here is the thing... if I find a sweet *** job that I make a huge amount of cash... then my budget for the engine will be significantly higher.. OH yeah and have you ever had the need to go faster but are stuck with a bagged 305..... its not fun..
