Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - swim goggles rock!
Old 03-17-2012, 12:36 AM
tech69 tech69 is offline
put up or shut up
Originally Posted by debrajt01
I will also use them for grinding and with a shield in front for under car grinding. Sounds like a plan, Stan. Less lens means less area for dirt and less area to wipe up to clean.
If you can get the Delphino ones cause you still have to cut little holes in them. The Delphino ones have a lip that hangs over the sides and you can put a couple 1/16" holes in there and they are completely covered. The chance of something gettig in there is the same with goggles with holes for anti fogging measures. They work great!
