Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Switch from 10si to 12si alternator
Old 09-26-2006, 05:49 AM
75gmck25 75gmck25 is online now
The original alternator on my '75 GMC pickup was a 63 amp 10si. I can switch to a newer 94 amp 12si with the same clocking, and its a direct bolt in. However, I also want to upsize the charge wire to 8 gauge with a 12 gauge fusible link.
When I run the new charge wire, should I use the original routing, which goes from the alternator down to the starter, or should I make a more direct connection to the batteery? Some of the newer trucks ('96-'99 vintage) use a charge wire directly from the bat terminal on the alternator to the battery, and do not route it down to the starter.
Bruce
