-   -   Switch from 10si to 12si alternator (http://www.hotrodders.com/forum/switch-10si-12si-alternator-99006.html)
75gmck25 09-26-2006 06:49 AM
The original alternator on my '75 GMC pickup was a 63 amp 10si. I can switch to a newer 94 amp 12si with the same clocking, and its a direct bolt in. However, I also want to upsize the charge wire to 8 gauge with a 12 gauge fusible link.
When I run the new charge wire, should I use the original routing, which goes from the alternator down to the starter, or should I make a more direct connection to the batteery? Some of the newer trucks ('96-'99 vintage) use a charge wire directly from the bat terminal on the alternator to the battery, and do not route it down to the starter.
Bruce
docvette 09-26-2006 03:38 PM
Doc here, :pimp:
The main problem with running the output wire to the battery, is that is is then subject to a more possible failures then it would be at the starter..
You run the risk of corrosion, and corrosion traveling up the wire (until it becomes unusable) Where as a Battery cable is a bolt on replacement, you now must remove and replace the wire..within the harness..It also becomes more prone to "becoming loose" as the cables are removed, cleaned , or the vehicle is worked on..Butt Splice Stub~outs are a nightmare also..
PLUS you really don't want a fuse link that close to a gassing battery..
The Starter location is one that has proved well over the years..and I advocate it..At best if it must be relocated..do so to a single terminal binding post at or near the battery, and make all your junctions there.
http://i4.photobucket.com/albums/y14...c/onewir13.jpg
You'll have a better system..
Doc :pimp:
