Switch from 10si to 12si alternator - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2006, 05:49 AM
The original alternator on my '75 GMC pickup was a 63 amp 10si. I can switch to a newer 94 amp 12si with the same clocking, and its a direct bolt in. However, I also want to upsize the charge wire to 8 gauge with a 12 gauge fusible link.
When I run the new charge wire, should I use the original routing, which goes from the alternator down to the starter, or should I make a more direct connection to the batteery? Some of the newer trucks ('96-'99 vintage) use a charge wire directly from the bat terminal on the alternator to the battery, and do not route it down to the starter.
Bruce
Old 09-26-2006, 02:38 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
The main problem with running the output wire to the battery, is that is is then subject to a more possible failures then it would be at the starter..
You run the risk of corrosion, and corrosion traveling up the wire (until it becomes unusable) Where as a Battery cable is a bolt on replacement, you now must remove and replace the wire..within the harness..It also becomes more prone to "becoming loose" as the cables are removed, cleaned , or the vehicle is worked on..Butt Splice Stub~outs are a nightmare also..
PLUS you really don't want a fuse link that close to a gassing battery..
The Starter location is one that has proved well over the years..and I advocate it..At best if it must be relocated..do so to a single terminal binding post at or near the battery, and make all your junctions there.
You'll have a better system..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 08:33 AM
another frustrating alternator problem darom Electrical 13 04-09-2006 11:09 AM
How do I switch from a generator to an alternator? professor-patrick Electrical 2 12-14-2005 07:32 PM
Remote Shut Off Switch doesn't shut it off! F-1Rodder Electrical 2 05-01-2003 04:01 PM
Alternator Switch dollybud Electrical 5 10-06-2002 04:50 AM
