Switch from 95 to - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-26-2012, 06:01 PM
Switch from 95 to
Have a 95 Chevy truck that I am switching computer to 97. I have a 5 speed tranny and the 97 had a automatic 4 wheel drive. Am I going to have to change sensors on transmission to adapt?
Old 11-27-2012, 09:22 AM
S10xGN's Avatar
Gotta love a turbo!
IIRC, the '95 ECM (OBD I) has a replaceable "chip", while the '97 ECM (OBD II) has a flash ROM that will need a programmer. I think your proposed swap will be more trouble than you're anticipating.
Russ
Old 11-27-2012, 10:35 AM
You're going to have to change more than just sensors. As noted above, the computers are completely different, and the AT computers have a different programming from the MT computers. Why do you want this headache?
Old 11-27-2012, 12:50 PM
I have all the wiring and computer,dash, heads,and intake.plus fuel system. It's a project truck but I just have a different tranny. So basically I'm going to have to get someone to reprogram computer for different transmission
Trans brake switch showing small voltage, is switch bad? pdmracing Transmission - Rearend 1 09-26-2011 08:50 PM
toggle switch / ignition switch help help! 39chevy Electrical 4 08-18-2006 07:04 PM
door switch and brake switch 49dream Electrical 5 02-11-2005 11:58 PM
DIY Shiftlight/ RPM Switch/ RPM Window Switch Junorr Electrical 2 09-07-2004 08:18 PM
