switch, alternator,starter, coil - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2009, 10:23 AM
This has probably been beat to death, but I need to hear it again or be able to find something to look at.
I am installing a '64 chevy 283 points distributor engine in a '70 Chevy panel delivery truck and need some help with wiring the switch to the starter and on to the coil. The alternator that i'm running is a little different than the snap connector that is with the harness. Which wires go to which terminal.
Thanks in advance. spcl
Old 11-19-2009, 06:58 PM
SSedan64's Avatar
May find what you need here>> http://www.madelectrical.com/electri...evymain1.shtml
Other Info>> http://www.madelectrical.com/electrical-tech.shtml
700r4 lock up confusion jrs22166 Transmission - Rearend 4 07-28-2009 08:35 AM
Operation of Vacuum Switch for TCC Lockup JohnTN Transmission - Rearend 1 07-10-2009 11:23 PM
Wiring a switch panel tommer2 Electrical 3 10-19-2008 01:28 PM
Postive ground but negative coil, strange one Nightfire Electrical 21 04-19-2006 05:20 PM
older headlight switch smoking! bigfred1958 Electrical 9 02-15-2004 08:31 PM
