Switch pitch benefits? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-03-2005, 12:34 AM
Hey all, I have a th300 switch pitch in my oldsmobuble right now, and I was just wondering what kind of benefits (EXACTLY) the switch pitch gives you? I have heard conflicting/vauge ideas of torque multiplication and stuff, I was just wondering what practically one would notice while driving? Is this setup (2 speed switch pitch) better or equal to a th350?
Thanks
Mark
Old 06-03-2005, 05:13 PM
No-one knows anything about switch pitches?
Old 06-03-2005, 06:25 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
since the original post was late in the day and I have a day job, there was no response from me..... sorry
The switch pitch converter is exactly that....... high and low stall speed in one unit. Say low stall is 1400 , high could be near 2200...... or low could near 1800 and high would be near 2600. That is an example stall range only
More stall , slightly higher torque multiplication in the high stall mode.
The fins inside the converter move/change angles. Only open or closed , they are not varible IE: 40% or 75% change in angle.
2 speed switch pitch is not a correct description of the operation of the switch pitch converter.
The switch pitch t-400 was primarily used on heavier vehicles. When the throttle was mashed hard..... a switch was activated, the converter went to high stall mode to allow the engine to rev up slightly higher givng the heavy car a better take off from a stop.
Comparison of a t-400 switch pitch to a regular t-350 is an apples to oranges compar-o IMHO
I hope this answers most of your questions
Old 06-03-2005, 09:30 PM
Hey thanks for the reply, all I meant was as far as the driving experience goes (acceleration/driveability) is my 2 speed switch pitch worse then a th350, as for example is it worth swapping in a th350? Would the car be more fun to drive or have more accerlation (in your opinion)? and would my city gas mileage maybe improve? Just things like that, from a purely day to day experience opinion.
Thanks
Mark
I would also like to know exactly how much torque multiplication the higher stall gives.
Old 06-03-2005, 10:56 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I believe I follow your " 2 speed switch pitch " comments now..... you must have a ST-300 tranny? Super Turbine 300
A tranny swap to a t-350 will give you a lower first gear , 3rd gear is 1-1 as the ST-300 is in 2nd gear.
Can't give you an exact amount of torque increase
Thanks
Mark
I want to install an underdash ignition kill switch in my 67 nova...can you help? batman09 Electrical 40 05-15-2005 09:47 PM
Help Wiring A Relay to A Dash Switch horvath Electrical 6 03-06-2005 01:58 PM
Rebuilding a TH400 switch pitch Wmarden Transmission - Rearend 2 09-15-2004 11:54 PM
older headlight switch smoking! bigfred1958 Electrical 9 02-15-2004 08:31 PM
Remote Shut Off Switch doesn't shut it off! F-1Rodder Electrical 2 05-01-2003 04:01 PM
