Switch from serpentine to V belt - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2009, 12:01 AM
454headache's Avatar
I have a GM OEM serpentine system on my 454. The previous ownersaid the set-up was from a '84 dually. It has A/C, that is not hooked up nor will it ever be hooked up. I'm just using it as an idler pulley. I want to get rid of it but I can not find a OEM serpentine system without A/C, and I do not want to spend the money on a aftermarket set-up. So with all this being said....
I want to switch to a V belt set up. My question is will I be able to use my current water pump, alternator, and power steering pump if I do? Or will any of these things rotate in the wrong way with a V belt.
Old 10-26-2009, 12:11 AM
Hmm never mind guys, looks like I found an idler pulley. So question is will this work?
http://cgi.ebay.com/ebaymotors/Chevy...item2ea4c54d9a
Old 10-26-2009, 02:23 AM
DoubleVision's Avatar
The bypass pulley will work fine. I`ve switched many a small block from V belt to serpentine, your the first case I ever seen wanting to do the opposite. glad you found something to compromise as it wouldn`t have taken long before you would have likely wished you hadn`t switched.
Old 10-27-2009, 02:32 PM
Amen to the above............
Old 10-28-2009, 03:48 PM
fast68's Avatar
likes chevy trucks & boobies
hmm interesting i never knew they went to serpentine so early on these.
earliest i ever knew they gm went to serpentine on the v-8 was in '85 with the 305 etc in the cars and trucks but it was only half serpentine
because i know the 84 were still v belt at least on the sb engines,
interesting..
got a pic?
you should be able to take everything from a v belt 454 and put it on yours.
Old 10-28-2009, 04:21 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
I'm *almost sure* that water pumps are the opposite rotation from v-belt to serpentine.
Deep 2 groove short W/P pulley or serpentine? fastrehotrods Engine 19 01-27-2009 02:50 PM
Fan belt problem on rebuilt 406sbc 406chevelle Engine 8 06-28-2008 11:53 PM
351 Windsor Serpentine belt change over? john35 Engine 3 12-28-2004 06:45 PM
Serpentine Belt drive on a 283? csangster Engine 10 10-07-2004 10:00 AM
older headlight switch smoking! bigfred1958 Electrical 9 02-15-2004 09:31 PM
