Switching to 200R Tranny question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2009, 09:48 AM
200r4 Tranny
I just installed a 200r4 in my wife 70 Monte Carlo. The swap was smooth the cross member had to move farther back than the 350 tranny location. The Monte had the holes there already. The drive shaft did not have to be swapped (same splines) same length. The only thing I had to change was the valve body. TCI sells a constant pressure valve body that saves the trans if low pressure should occur about 200 bucks. Make sure the TV cable is adjusted if it is not your trans will die prematurely. Good luck and take your time. Google the install you will find a bunch of info.
Old 02-01-2009, 09:53 AM
SSedan64's Avatar
Check the date of the threads, this ones 5yrs old.
Old 02-01-2009, 09:56 AM
Crosley's Avatar
Wiki Edits: 1659
Overdrive1939 , welcome to Hotrodders...
when searching threads ; read the dates on threads is a good suggestion.
