SWITCHING TO A 400 TH from a 350 TH - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-22-2004, 03:40 PM
70SPORT's Avatar
I will be putting in a 400 th in my car. it came equipped with a 350 th.....will everything line up or will i need to make changes ? like crossmember yoke or drive shaft.....not sure what im getting into and what i will need to do it right......any help would be great....its going in a 1970 pontiac lemans. i know the gto 's came standard with a 400 turbo ...lemans is the same as gto other than the badging.........thanks
Old 06-22-2004, 06:23 PM
BOBCRMAN@aol.com's Avatar
The 400 cars had a different crossmember, shorter driveshaft with larger U-joints and a larger Yoke. Also had a "kickdown" switch wired to the throttle linkage for "Passing gear".
400 trans is longer, has larger output spline and uses electric switch, rather than a cable, for throttle position sensor.
Old 06-22-2004, 06:50 PM
70SPORT's Avatar
i heard that the cross member would be the same ...i also heard i would need a differnet yoke and have to have my drive shaft cut....to fit
Old 06-22-2004, 08:40 PM
why are you swapping to a 400 btw?
Old 06-22-2004, 09:06 PM
What kind of car is it?
Old 06-22-2004, 09:41 PM
70SPORT's Avatar
I was going with the 400 th because I have about 450 hp and I thought it would be more bullet proof......i was going to get my 350 th rebuilt but my buddy offered me a 400 th..
Old 06-23-2004, 12:53 AM
I see well the choice is yours just keep in mind that a 350 properaly build 350 would also live fine in the situation. As for your question unless the tranny is a 375 verson of the 400 you will need to get your yoke changed. And you will need to have your drive shaft shorted and a 400 cross member which shouldn't be to hard to find. As for the electric kick down your best bet is to get a retro fit kit which I believe b&m sells as well as a few other companies
