Switching to AFR heads, is my cam ok? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2012, 04:30 PM
Basics of my engine:
350 4 bolt, .060 over
Flat top pistons (speed pro cast)
Lunati bare bones 1001lk cam
edelbrock intake (dual plane)
Holley 750 vacuum sec
Full headers, 2.5" exhaust, flowmaster 40's
Camel back heads (about 63cc, not the 2.02's)
STOCK gears
Jegs 2400-2700 stall
Basically my neighbor is a cool guy, he's old, retired, tired and he's giving me a set of 64cc aluminum afr heads in exchange for pulling the motor (actually he's giving me the whole motor). I know little about them. He says I have to use the intake he's got because the chambers have been opened up. The intakes are bigger than 2.02 also (I think he said around 2.10?)
I know, there is not alot to go off here, and I'm an amateur who before finding this forum, just threw parts on to see what would happen. Basically he said I should be around 10.5:1cr, and with my cam and these heads my engine should be pretty quick. What do you guys think? Should I change the cam? Will these heads be too much? BTW, I do plan to change to a 4.10 gear in the future.
Old 05-16-2012, 05:09 PM
What size AFR heads? They make/made a 180, 190, 195, 210, 215rr, 220, 227, 235, 245............
I wouldn't go over 195 for a street 350. If you put something bigger on that small of a motor it will want to sing to 7500rpm to make its power. What cam specs do you have right now?
Old 05-16-2012, 06:21 PM
Hydraulic flat tappet
Basic Operating RPM Range 1,500-5,500
Intake Duration at 050 inch Lift 214
Exhaust Duration at 050 inch Lift 224
Duration at 050 inch Lift 214 int./224 exh.
Advertised Intake Duration 280
Advertised Exhaust Duration 290
Advertised Duration 280 int./290 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.443 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.465 in.
Valve Lift with Factory Rocker Arm Ratio 0.443 int./0.465 exh.
Lobe Separation (degrees) 112
It's not a huge cam, he's using a roller cam with 660 lift so there's a big diff. I'm not sure on the head size, probably 210, I remember him mentioning that. I guess they were used on a bracket racer. I can always go to a bigger cam if I have to, I just can't get above 6000 rpm because I have a stock bottom end. These heads are comming off a sbc 350 with basically the same bottom end (except he used a 2 bolt, he just never revved it over 6k).
Old 05-17-2012, 06:15 AM
cool rockin daddy's Avatar
1.21 giga-watts???!!!!
Why in the world wouldn't you get the part number off the head, call AFR, and ask them their opinion of your combo?
Old 05-17-2012, 08:16 PM
A 210 will work on a high rpm 350 but not a low-end grunt motor. That cam you have is way to small to make GOOD use of those heads on 350 cubes.
Best cam size for my 327 with AFR 180cc heads? 67CamaroRsSs Engine 5 02-29-2012 01:33 AM
AFR or Vortec heads? Cam? rodent Engine 18 06-08-2010 03:50 PM
Afr 195 Heads...cam? wilkinr16 Engine 3 06-24-2007 01:29 PM
Switching Heads??? budthespud Engine 13 06-11-2007 05:23 AM
Switching heads 47chevrolet Engine 10 01-18-2007 11:48 PM
