Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Switching cam shaft to fix fuel pump on 1988 Dodge Dakota
Old 03-07-2013, 05:17 AM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
Simple solution
Get a common aftermkt low pressure electric fuel pump and install/wire it correctly. No regulator required and sure beat the h@ll out of pulling the front and top off an engine.
Fuel pump lobe wear is getting to be more common as the oils available are junk. Don't protect from direct rubbing forces.
