Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Switching cam shaft to fix fuel pump on 1988 Dodge Dakota
Old 03-07-2013, 02:17 PM
33Willys77's Avatar
33Willys77 33Willys77 is offline
This motor does not have a lobe on the cam for the pump. It is a part (round offset stamped steel) that bolts to the front of the timing gear - called a fuel pump eccentric.
The Following User Says Thank You to 33Willys77 For This Useful Post:
One to Remember (03-07-2013)
