Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Switching cam shaft to fix fuel pump on 1988 Dodge Dakota
Old 03-07-2013, 04:28 PM
33Willys77's Avatar
33Willys77 33Willys77 is offline
To get to it, you would need to pull apart the front of the engine. There will not be much contact on the fuel pump arm. Sounds like you have more issues than a fuel pump if a stock pump is making the carb overflow. You need to clean out the lines and carb. What is on there for a carb? If you really feel there is too much pressure, put a guage on it. 88 Dakotas did not come with V8s, (exception of Shelbys). Chrysler did not put V8s in until I believe '93 (newer style). Someone put it in, so find out what the engine is.
The Following User Says Thank You to 33Willys77 For This Useful Post:
One to Remember (03-07-2013)
