Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Switching cam shaft to fix fuel pump on 1988 Dodge Dakota
Old 03-09-2013, 08:54 AM
PatM PatM is offline
Not knowing a LOT more about the engine, I cannot be certain, but I'd be concerned that the ProProducts pump shown would be a little bit light @ 28 GPM. Carter makes a simple electric internally regulated vane pump (regulator not required) that will pump up to about 72 GPM also at about 4-6 PSI. Check out Carter Universal Rotary Vane Electric Fuel Pumps GP4070 - SummitRacing.com
Edit: Note that if you find it necessary, this pump can be further regulated with an in-line (non-return) regulator.
PatM
The Following User Says Thank You to PatM For This Useful Post:
One to Remember (03-09-2013)
