Switching gears again - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-03-2011, 02:41 AM
American Muscle's Avatar
305 Turbo-Fire 240hp
Not for sure if this belongs here but here goes. I was thinking of changing my gears in my truck. Have 342 and a 700r4 now and really like the holeshot performance but of course as a performance junky I want more. I was leaning toward 373. I was wandering will the added rpm increase in the lower gears paly in role in more rare and tear on my motor. Mind you my motor isnt expensive or monsterous in power at all. Just a calm, nice driving 305 that sees some tire peeling once in a while. just stop light to stop light revs. I wont beat on it often, just occasionally. Should I stick with 342 or gone upgrade to 373.
Old 11-03-2011, 10:12 AM
With a numerically higher rear end ratio, the normal orerating RPM range will be higher. The increase in wear, in all gears, not just lower ones, will be negligible, but expect somewhat less MPG.
Switching a 350 out for a 454 Jaypup3 Hotrodding Basics 0 06-01-2011 09:54 PM
switching out rear end gears 18camaro Transmission - Rearend 3 10-21-2007 03:57 PM
SWITCHING TO A 400 TH from a 350 TH 70SPORT Transmission - Rearend 6 06-23-2004 12:53 AM
Switching gears, the fun way johnsongrass1 Transmission - Rearend 0 08-10-2003 09:04 PM
switching power steering gears Impala Stuart Suspension - Brakes - Steering 3 03-25-2003 03:49 PM
